Posted by lmack on June 30, 2014 at 15:51:38 from (24.131.50.165):
In Reply to: Re: Run in Shed posted by J Strickland on June 30, 2014 at 05:50:38:
James,
I would suggest that you do what you have to do to come up with some bracing. With these summer storms we are having just one good blow could put your nice shed on the ground and you will have lost the money you have already invested. You are not finished until the bracing is in place. If you can"t afford much, a 4' 2 x 4 on a 45 each way will help a lot. For the front to back an X brace of 7/16" cable will do. If you X brace just one bay at the rear with cable and use 4" 2 x 4"s one each post on the high end it will do fine. You will have to brace every post both ways on the outside to have enough knee bracing. If your post are dug into the ground and set in concrete bracing for the short time is not as important, but you will need it in the long run since the treated post will rot out in about 20-years unless you are below the fall line in Georgia in which case they will be gone in 10 years.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
