Posted by pete 23 on June 30, 2014 at 18:16:20 from (173.87.0.139):
In Reply to: Farmall H Water Pump posted by Brandon K on June 30, 2014 at 18:01:36:
That hole should have a grease fitting in it. If you have the old pump take a look. They normally have a fitting with a cap on but any one will work. That passage goes into the impeller right between the two brass bushings. The packing is in front of the front bushing so just a little bit of grease every once in a while to help lube those bushing. There should also be another grease fitting in the hub to lube the ball bearing in the hub.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
