Re: Broken Whip Mower
Posted by rustcollector on June 30, 2014 at 18:51:39 from (72.104.28.33):
In Reply to: Broken Whip Mower posted by Sparky70 on June 30, 2014 at 17:51:25:
Sparky 70,
This "Joint" should be a slip joint and the remainder of the square shaft should pull out once you get the twisted shaft started out of the end slightly. Check the shaft for being square or about 1/8 inch more in one dimension? They will have one dimension a little larger and cannot/should not go together but one way. This keeps the universal joints aligned. Be careful to repair the shaft in the correct alignment.
