Re: farmall H questions
Posted by rankrank1 on June 30, 2014 at 19:37:37 from (198.228.228.150):
In Reply to: farmall H questions posted by pasbonbasile on June 30, 2014 at 15:03:11:
The suffixes after the x will determine the options (if it had any).
Examples: gas only, low speed gears, high speed gears etc.
As for the hydraulics: Any of the pipe 3 ports can be used but there is a delay with the rear port on the left side. This was on purpose for when front mount cultivators were used. The sections that trailed the rear wheels would be plumbed into that delayed port so that they would raise and drop after the front mounted cultivators would which would be plumbed into the front ports. In short, use the front ports on either side.
This post was edited by rankrank1 at 19:38:16 06/30/14.
