Posted by pete 23 on June 30, 2014 at 20:06:16 from (173.87.0.139):
In Reply to: Farmall H Water Pump posted by Brandon K on June 30, 2014 at 18:01:36:
It is normal for coolant to be in that passage. Like I said, there are two bushings the impeller shaft rides on and there is a space between them. The packing that prevents leakage to the outside end of the shaft is behind that packing nut on front end. After you plug that hole the coolant will try to get past the next bushing and the packing. If it seeps a little tighten the packing nut some.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
