Re: Broken Whip Mower
Posted by mkirsch on July 01, 2014 at 08:33:55 from (65.199.189.6):
In Reply to: Broken Whip Mower posted by Sparky70 on June 30, 2014 at 17:51:25:
Nope, no threads on a PTO shaft. It will either be welded to something or slips on something and is held by a clip.
If you wanged it that hard, you probably didn't do the U-joints any good either. Easiest thing to do is replace the whole shaft, joints and all.
Tractor Supply has an assortment of PTO shaft parts and PTO shafts, but you may need to visit 2-3 stores because they rarely keep more than one of any given PTO part in stock, and if that one is sold it won't be restocked until a truckload of supplies are needed.
