Re: i h 2500
Posted by mkirsch on July 01, 2014 at 08:36:58 from (65.199.189.6):
In Reply to: i h 2500 posted by rehix60 on June 30, 2014 at 20:09:29:
100% positive it uses CaseIH "HyTran" brand fluid.
There are also compatible fluids. Look for fluids that meet MS-1209 specifications or say "Hytran Compatible" on the can. Do not use anything that doesn't at least say it's compatible with Hytran.
Hytran is not cheap. If you can spring for the real stuff, you probably should, but if you can't then at least use compatible fluid.
