Re: McCor.10-20
Posted by rustred on July 01, 2014 at 09:44:14 from (74.214.152.80):
In Reply to: McCor.10-20 posted by F30 on June 30, 2014 at 19:33:44:
sometime it takes a pull with another tractor. make sure the mag. has a hot spark also. could be the condenser
squirt a few shots of gas mixed with some oil into each plug hole. if she starts for a few seconds you have a carb problem.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
