Re: cub, fuel shut off, what happened?
Posted by old on July 01, 2014 at 10:48:52 from (209.86.226.59):
In Reply to: cub, fuel shut off, what happened? posted by ericlb on July 01, 2014 at 09:45:11:
I would drain the tank by removing the line at the carb and hooking up a hose to it so as to be able to put the gas in a can. Then I would pull the sediment bowl assembly off the tractor and see if maybe some rust/dirt has not gotten in the shut off area of the sediment bowl assembly keeping you from shutting it off and to take the valve off and clean it up
