Re: McCor.10-20
Posted by F30 on July 01, 2014 at 16:13:33 from (199.87.138.221):
In Reply to: McCor.10-20 posted by F30 on June 30, 2014 at 19:33:44:
Had the mag tested recharged. Will shot fire a good 1/4 of inch. Did not put a new manifold gasket on so I will get a new one. Lisning to every ones comments it sounds like fuel. It has steel wheels on it so I have to put my new rubber bars on so I can pull it Thanks for all the advice. Red Puller
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
