Posted by El Toro on July 01, 2014 at 17:15:15 from (96.244.7.206):
In Reply to: McCor.10-20 posted by F30 on June 30, 2014 at 19:33:44:
Are you sure your mag is timed to No1 piston near the radiator when that piston is at TDC on the compression stroke? Once you have No1 piston at TDC pull the cap on the mag and see where the rotor is pointing. Should be at the No1 plug tower on the cap. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
