Re: McCor.10-20
Posted by F-Dean on July 02, 2014 at 03:50:30 from (70.194.101.160):
In Reply to: McCor.10-20 posted by F30 on June 30, 2014 at 19:33:44:
Do you have the timing in the right direction? Clockwise from driver's view. (Yes, I learned this problem by experience!)
Try starting with a twisted belt. You can stand by the engine and try various adjustments while the engine is turning.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
