Re: 560 with 3-14 fasthitch plow
Posted by SD Pete on July 02, 2014 at 19:19:46 from (24.230.163.196):
In Reply to: 560 with 3-14 fasthitch plow posted by slifnom on July 02, 2014 at 17:11:15:
I used to too pull the pins on each side so it would bounce up if you hit a rock. Then a pin in between the arms so the plow was free to swing.
