Re: alternative head crack repair (pic)
Posted by HillBillyRockStar on July 02, 2014 at 20:06:23 from (24.247.83.93):
In Reply to: alternative head crack repair (pic) posted by biggerred on July 02, 2014 at 18:52:56:
Ive seen pins work Ive also seen them fail. Last one I seen fail hole was drilled and tapped to deep along inside of combustion chamber. Chamber wall failed where it was drilled but pin didn't fill void.
