Re: 706 3 point sway blocks
Posted by mkirsch on July 03, 2014 at 04:57:51 from (65.199.189.6):
In Reply to: 706 3 point sway blocks posted by mattsillinois on July 02, 2014 at 07:17:10:
No, they do not make sway blocks.
BillOHIO is correct, there should be a sway linkage, but it only has limited effectiveness. The hitch still sways a lot more than more modern systems.
