Re: Super A Left Rear wheel heating
Posted by Hugh McKinney on July 03, 2014 at 08:00:44 from (173.202.172.156):
In Reply to: Super A Left Rear wheel heating posted by Tim Pazda on July 03, 2014 at 06:57:05:
The brake was probably slightly on. One way to check is to jack up that wheel, be sure to block the other wheels for safety, and put the trans in neutral. See if you can rotate it easily. Check to make sure that the brake on that wheel is released. Check it again. If it still drags, you could have a bearing problem on your axle. But I'll bet it was a brake that wasn't fully released. It happens all the time. Doesn't usually amount to much, other than shortened life of brake shoes. Email is open if you need to write. Hugh
