Posted by WellWorn on July 03, 2014 at 11:15:11 from (75.250.248.224):
In Reply to: Quick question posted by Parmenion on July 03, 2014 at 08:17:41:
The answer is "depends".
Has the Super C had the 3pt conversion kit?
What do you intend on cutting with it?
How big a brush hog?
I have an old JD 5' "hog" that I use on occasion with my Super A to cut overgrowth from pastures, BUT:
1) the front gets pretty 'light' when carrying it.
2) You will need an overriding clutch on the PTO output shaft (don't leave home without it!)
3) On a full cut it requires more HP in tall grass or heavy weeds than the SA can provide, even in 1st gear. The SC would be about the same, depending on year.
4) The hog should have a lower ground speed to work best,
5) it should be run from a live PTO (with an overriding clutch).
If I had a choice, I'd use a bigger, better tractor for brush hog work, but my bigger better one is in the long (costly) process of an overhaul.
This post was edited by WellWorn at 11:19:10 07/03/14.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
