Re: Disk blades
Posted by DeltaRed on July 04, 2014 at 22:21:43 from (65.100.145.84):
In Reply to: Disk blades posted by Farmall4856 on July 04, 2014 at 11:13:52:
Take the thing apart and MEASURE the center hole and axle to be sure.Then order your parts.18" blades were probably stock.Again,MEASURE the diameter of both front and rear disk blades to get a 'feel'.Them measure from the center of the gang bolt out to the frame.Then you will know just how big a blade you can install.
