Are you using OEM coils, or coils from an auto parts store?
If the tractor uses a ballast resistor, use a coil marked "for use with external resistor".
If the tractor does NOT have a ballast resistor, you need a "true" 12 Volt coil designed for such use. Contrary to what many guys believe, they do NOT have a resistor inside them, they are simply wound with more turns of wire.
The other issue COULD be if the tractor has a ballast resistor and it is nor properly connected into the primary ignition circuit.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
