Thanks for the help Bob. I checked the alternator output on both tractors while running. The tractor without issue was putting out 14.5 volts while the tractor with coil problems was putting out 17.5 volts. Is this enough voltage to cause coil problems?
I guess my volt meter isn't too accurate at low ohms. It's helpful to compare the two systems only. The voltage readings seem to be OK.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
