Re: International 454
Posted by richardinnz on July 05, 2014 at 15:55:42 from (222.153.154.60):
In Reply to: International 454 posted by MAH on July 05, 2014 at 14:22:41:
IF the fuel is from repeated failue of the seal of the injector pump, then you may have a restriction in the fuel return circuit.
Also check the thermostart cold start aid if one is fitted.
