Posted by IAtractorKid on July 05, 2014 at 19:36:06 from (184.97.36.176):
In Reply to: Farmall M, no spark posted by bja105 on July 05, 2014 at 19:09:39:
That's a ceramic resistor. Allows you to use a 6V coil on tractors converted to 12V. Its not needed if he has a 12V internally regulated coil. If the coil says its externally regulated, its essentially a 6V coil and requires that ceramic resistor.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
