Posted by El Toro on July 06, 2014 at 03:57:50 from (96.244.7.206):
In Reply to: Farmall M, no spark posted by bja105 on July 05, 2014 at 19:09:39:
Try cleaning the points with a piece of 320 wet or dry until they're shiny. If you need a new coil buy Napa's 12 volt coil IC14. No ballast resistor is required. First install a new condenser and make sure your points are opening and closing. The rubbing block maybe worn. Make sure your rotor is turning when cranking. Your cam gear may have failed. Hal
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
