Posted by El Toro on July 06, 2014 at 04:18:26 from (96.244.7.206):
In Reply to: Farmall M, no spark posted by bja105 on July 05, 2014 at 19:09:39:
Remove No1 plug near the radiator and bring that piston to TDC on the compression stroke. Then remove the distributor cap and see where your rotor is pointing. Should be at the No1 plug tower. If its off your cam gear probably failed. Hal
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
