Posted by John A. on July 06, 2014 at 10:46:29 from (64.128.16.238):
In Reply to: 756 or 766 posted by MNHighwired on July 06, 2014 at 01:42:21:
MNHighwired,, Either Tractor is a good choice. #1 are you wanting a Large frame or Small frame tractor??? #2 a tandem axle W/ single 7500 lb axles as opposed to a tandem axle W/ Duals 10000 lb axles to haul it! #3 a 756 is a Small frame tractor, the 766 is a Large frame tractor or In simpler terms... a 80 hp tractor in a 966/1066... 95 to 135 hp body and wt. To me this is the key to you Question Will you be hauling it around, have a trailer or need to get a trailer....... the 756 will haul on a tandem, singles trailer the 766 will haul only if not weighted! But you said you want to put a Loader on it so weights are a Must! A 766 will weigh in at near 12000ls if weighted right. A 2350 IH Loader will bolt On no mods needed, It is built for these tractors! Either way You cant go wrong Part is No Problem ! Hope this helps. Later, John A.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
