Re: SA Loader Problem
Posted by mkirsch on July 07, 2014 at 04:43:17 from (65.199.189.6):
In Reply to: SA Loader Problem posted by Doug Kieta on July 06, 2014 at 15:11:17:
My money's on the spool valve, due to the single-acting boom cylinder.
What Ed says, means you'd see a puddle of oil form on the ground as the loader crept down. No puddle. Not the cylinder.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
