Re: 48841D Pivot Pin Bushings
Posted by caterpillar guy on July 07, 2014 at 07:45:58 from (24.247.90.160):
In Reply to: 48841D Pivot Pin Bushings posted by IAtractorKid on June 29, 2014 at 07:06:02:
Buy a bushing in the correct OD size and either bore it to fit or ream it to fit. A brake cylinder hone will work if it is close. You will with this form have to fit it to the shaft after it is in the casting to account for crush as it is pressed in.
