Re: Stuck In Reverse
Posted by famousfather on July 07, 2014 at 14:53:10 from (75.133.49.203):
In Reply to: Re: Stuck In Reverse posted by gene bender on July 06, 2014 at 16:22:17:
Yep, lined up the shift rails like you said and it now works. Thanks, Gene!
