Re: Thinking about getting a new tractor
Posted by rankrank1 on July 07, 2014 at 18:36:28 from (166.137.101.152):
In Reply to: Thinking about getting a new tractor posted by JRSutton on July 07, 2014 at 10:43:42:
Since you are strongly considering a 560 gasser , then I would give a Farmall 706 gasser a strong hard look instead.
a) Fuel consumption will be real similar between the two.
b) 706 much more modern ergonomically.
c) 8 speed tranny in the 706. Only a 5 speed tranny in the 560.
d) Torque Amplifier if equipped and it works properly will double the speeds to 10 for the 560 and 16 for the 706.
e) The Low side of TA will free wheel on a hill on the 560. The low side of a 706 will not free wheel on a hill as it has the improved TA design.
f) 706 has a few more hp
Huge advantage to 706 in every way IMOP for likely similar money.
This post was edited by rankrank1 at 18:37:45 07/07/14.
