Clutch on 300
Posted by VaGasman on July 08, 2014 at 05:01:53 from (75.192.44.250):
I have noticed that when moving roundbales with rear spear, when I back into to position and want to shift out of reverse there is a lot of drag on shifter to shift out. Then sometimes if I am in forward gear against a grade there is the resistance again when I want to shift when in a stopped position. I tried adjusting clutch in a little farther but didn't make a difference. any recomendations?
