Re: 706D oil pressure
Posted by Montour PA Steve on July 08, 2014 at 08:24:11 from (70.192.141.90):
In Reply to: Re: 706D oil pressure posted by Allan In NE on June 29, 2014 at 05:16:50:
This motor was just overhauled - it has new rod and main bearings, sleeves, pistons and rings. The head was also totally gone over. We did not put new camshaft bearings in it. I got another pressure gauge and saw the same response. I took the leap for a remanufactured oil pump and it made no difference. There isn"t much left to check. I checked the relief valve spring in the filter housing and it looks fine too. Not sure what else to check. Sorry it took a while for the response. Thank you for the help!
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
