Re: Cub Head Gasket
Posted by T_Bone... Quick Temp Fix! on December 28, 2000 at 21:10:45 from (207.254.53.115):
In Reply to: Cub Head Gasket posted by Red Raider on December 27, 2000 at 15:18:35:
Hi RR, Everyone else suggested the correct fix. For a temp fix use sodium silicate (egg whites). You get it at any pharmacy (why I don't know) in pints about $5, and put in no more than 1/4 of a pint or it'll plug up the cooling system. Pour in while running. Will last for several months and takes less if your using anti-freeze. I've used to seal diesel head gaskets and it works very well. The only way to get it out of the system is flush alot with clean water letting it get to running temperature each time.
T_Bone
Post A Followup
: Re: Re: Cub Head Gasket
