Re: 710 plow on 560 with fast hitch
Posted by mkirsch on July 09, 2014 at 05:29:20 from (65.199.189.6):
In Reply to: 710 plow on 560 with fast hitch posted by Brad Vaughn on July 07, 2014 at 19:50:18:
I know the 540 semi-mount plow was available with short, straight fast hitch adapters for use with the 560. Apparently it lifted high enough for that.
I mean, they're SHORT. I have a set at home, and they barely extend 6" out of the socket. Way shorter than your typical fast hitch adapters. The longer the adapters are, the higher they will lift the plow.
The 710 did come in a 3-bottom version, so cutting it down should be no problem. You can also raise and lower the hitch head, as well position it side-to-side to compensate for the change in the center of draft when you cut it down from 5 bottoms to 3.
I think it will work.
