Gears do not like wobble in any direction that sure needs to be fixed, look for wear on the shaft as well as the gear. If the pump turns with the eging rotation and no noises in the clutch area were evident it might be a priming/intake issue. if the pump does not turn, it is likely the drive splines in the tubular shaft at the clutch plate. But do not saaume it will be OK with gears out of proper mesh.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
