Posted by Bob M on July 09, 2014 at 21:00:45 from (74.67.188.246):
In Reply to: H running rough posted by Peter Hoyt on July 09, 2014 at 20:43:04:
A cracked head, block or bad gasket can let coolant into the oil and cylinder(s) without showing externally.
A worn distributor shaft can indeed make timing jump around and cause the engine to run poorly. So first thing I'd do is check it with a timing light.
Timing should be TDC at low idle, advancing gradually to 35 - 40 deg BTC at high idle. If timing does not advance as RPMs come up the distributor centrifugal advance is stuck and needs attention. Or if the timing mark "dances" (randomly jumps around) the distributor bushings/shaft are worn - time for a rebuild.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
