Re: Installing a 140 manifold on an A
Posted by Mr. Farmall A on July 10, 2014 at 11:11:35 from (68.32.185.8):
In Reply to: Installing a 140 manifold on an A posted by Mr. Farmall A on July 09, 2014 at 23:59:51:
Thanks for the info guys, I suspected the 140 might have larger ports in the heads than a A. Mismatched sized ports can cause flow restrictions which is bad for power.
My manifold bolts are good because I had to take the manifold off to have my A's head milled flat again (bad head gasket), which bumped compression a little.
Just a little idea I had.
