Re: Need help with H throttle linkage
Posted by FBH44 on July 11, 2014 at 11:48:23 from (64.85.215.20):
In Reply to: Need help with H throttle linkage posted by bassmasta76 on July 11, 2014 at 11:10:35:
Wow, I might be wrong here, and do not hve a camera, and I didn't take off my hood, but I think you're missing some parts;
1. There's a spring in mine, keeps a equalizer bracket centered, where the throttle rod bolt runs thorough the Y-bracket. You don't have them.
2. I don't think there is supposed to be a nylon-lock-nut and a separate bolt and some extra nuts in there.
3. Note, the throttle rod is not a solid rod, it is a hollow tube on mine, [tragic tale], so yours might have been broken and repaired on yours. Might be shorter than original.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
