Re: My New Old H
Posted by gene bender on July 12, 2014 at 11:46:28 from (67.55.226.121):
In Reply to: My New Old H posted by Jon Lemke on July 12, 2014 at 09:57:48:
First i would get the starter refreshed then get new 1ga cables ground to the starter that will make the starter work like new again. Now the charging system. With an ohm meter check the gen one lead to the ground other to the gen body to make sure it has good ground same with regulator and lite sw if you polorize the gen it should charge providing the wiring is OK. You can put the probe on the knob of the lite sw to check it as all componets in the charging circut need to have ground to the battery as paint ect on other parts of the tractor are hard to find bare metal so i just check to make sure they have ground to the Pos terminal of the battery.
