Re: wrist pin wont fit in new bushing in rod
Posted by Bob on July 12, 2014 at 14:01:25 from (64.255.159.192):
In Reply to: wrist pin wont fit in new bushing in rod posted by Rock2000 on July 12, 2014 at 13:33:42:
The rod bushing has to be "sized" after installation, on a specialized machine to keep the wrist pin and "big end" bores parallel.
The video linked below shows the "big end" being honed, the procedure is the same for the little end.
The rods NEED to have the "big ends" checked, and be checked for straightness, as well. That is standard procedure when doing an OH.
I ASSUME the piston is aluminum... if the pins came with the pistons, they likely will fit correctly.
With the pistons WARMED and the pins lubed with light oil, they should pass through the pistons with thumb pressure.
You don"t WANT them looser than that.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
