Re: Farmall M Conversation with GM-Detroit Diesel 3-71
Posted by BoB M on July 13, 2014 at 12:16:29 from (74.67.188.246):
In Reply to: Re: Farmall M Conversation with GM-Detroit Diesel 3-71 posted by Robert in KY on July 13, 2014 at 09:57:46:
For a show/play tractor a 3-71 would be fine. But for a "working" M, a 3-71 repower has a high risk of tearing up the transmission/rear end. (Keep in mind he M rear end is designed for about 40 HP - a 3-71 easily delivers 120 HP.)
Not certain however whether there's sufficient frame length to shoehorn in a 3-71 (it probably can but it will be tight). The shorter 3-53 would be the better choice if you really want a 3 cylinder, Detroit-powered M.
Regarding pullers running small block V8's, these develop their power by running much higher RPM's. The torque delivered to the rear end may actually be not a whole lot more that of a stock engine. Further, a puller tractor transmission only to needs handle this for a few seconds during a pull.
