Posted by Centex Farmall on July 13, 2014 at 13:30:33 from (72.105.161.19):
In Reply to: Re: My posted by Butch WI on July 13, 2014 at 10:56:58:
They're used to keep the engine temp in the "operating range" on the gauge so as to be able to run on distillate. You warmed up on gasoline from the small tank and then once warmed, switched over to distillate (or kerosene). The critical part was the intake manifold. The exhaust part encircled the intake tube and kept it very hot so as the vaporize the oily fuel. A gasoline manifold has a shared wall between exhaust and intake to provide some heating and an LP manifold has no contact between the two.
Distillate was made from leftover refinery products from when crude oil was distilled rather than cracked. A barrel of crude would yield a certain percentage each of gasoline, diesel, lube oil, naptha, tar etc. When the War got going we really needed to be able to turn a barrel of oil into a barrel of gasoline, so they pushed catalytic cracking technology and did just that.
John Deere's version is called "All-Fuel" and basically the same idea. In the UK the fuel was called TVO for "Tractor Vaporizing Oil"
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
