Re: brake pedals
Posted by mkirsch on July 14, 2014 at 05:33:12 from (65.199.189.6):
In Reply to: brake pedals posted by 1948jr on July 13, 2014 at 23:33:29:
How is it stuck?
Spray some PENETRATING type oil such as PB Blaster or Kroil on the pivot points and work the pedal back and forth. Keep spraying and working until the pedal is loose again.
Sometimes you will need to heat up the pivot point with an oxy-acetylene torch.
It all depends on what's stuck, though...
