Re: JB Weld for MTA crack?
Posted by Bill Lisbon on July 14, 2014 at 12:09:10 from (69.89.162.253):
In Reply to: JB Weld for MTA crack? posted by BigTone on July 14, 2014 at 11:02:43:
Been there, didn't do that. To fix it right split tractor, turn housing upside down, I did this with out taking tires off, just flipped it over. Clean all oil out of crack, when you think you have it clean enough, clean it again. Weld it with cast iron rods, or braze it. You could cover the weld job with J-B weld to seal up any small cracks or holes in the weld. Do it once do it right.
