Re: Hiesler 9 speed shift lever
Posted by farmallhal on July 14, 2014 at 15:29:46 from (76.2.170.208):
In Reply to: Hiesler 9 speed shift lever posted by rick56 on July 14, 2014 at 10:20:06:
Rick, Welcome to the forum and I obtained the measurements you asked for off of my 1951 Farmall M with the Hiesler 9 speed on the tractor. The overall length is 16" and the spacing between the pivot point hole and the one for the actuator rod near the bottom is 4.5". The lower hole is very close to the bottom of the Hiesler lever with enough surrounding metal for a sufficient edge margin around the hole. Hope this is what you are needing if something else is required my email is open, Hal.
