Re: JB Weld for MTA crack?
Posted by Centex Farmall on July 14, 2014 at 20:57:17 from (72.105.160.200):
In Reply to: JB Weld for MTA crack? posted by BigTone on July 14, 2014 at 11:02:43:
Depending on the size of the damaged area, my concern would be to stop the crack from propagating further. JB weld may stop the leakage but won't hold the iron together. Since this one is worth keeping go ahead and plan to braze or weld.
