Rock2000 said: (quoted from post at 21:01:00 07/14/14) Well you're right that I don't like it. :)
If the rod tolerances were not great than I guess there is no getting around that. But I don't really see why the same problems don't occur with main or rod bearings. They need to have around 3 thousandths clearance, and I can buy a standard 10 thousandths oversize bearing set that I can just install and doesn't require any further custom work. I have to have the crank made to spec, but that is similar to having the wrist pin to spec (which it should be since it's new in this case). I don't need to (generally) worry about the the block or rod holes that house those bearings though, and I don't need to worry about any custom work on the bearings after I install them. So why is this bushing so much different?
Thanks
Rock
That's just the way it is.
This post was edited by Jim Naden at 03:53:28 07/15/14.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
