Re: JB Weld for MTA crack?
Posted by BruceS. on July 15, 2014 at 04:51:47 from (24.161.33.112):
In Reply to: JB Weld for MTA crack? posted by BigTone on July 14, 2014 at 11:02:43:
I agree with others that brazing is the best solution as you want a garanteed permanent fix.
That said, jb weld has certain uses...I fixed a short crack in an f30 block 15 years ago and its still holding fine. No cooling system pressure on these,of course.
