Re: Brazing cast...??? (follow-up thread)
Posted by matt from Oz on July 15, 2014 at 05:07:57 from (220.235.250.10):
In Reply to: Brazing cast...??? (follow-up thread) posted by BigTone on July 15, 2014 at 04:46:01:
Tone it can be done we did it restoring an H. Found the housing
was cracked under a bull gear in the tranny. Had to drain the oil
split the tractor then invert the housing. Got a gurru local metal
worker who used a small grinder to open the crack then braze it.
with the heat it would run so chased it with the grinder and braze
until it stopped. This has held up with no problems. It was a big
job but easier than changing the housing.
