Re: wrist pin wont fit in new bushing in rod
Posted by Owen Aaland on July 15, 2014 at 13:34:22 from (216.47.34.49):
In Reply to: wrist pin wont fit in new bushing in rod posted by Rock2000 on July 12, 2014 at 13:33:42:
The pin bushings are fitted with 1/10 the clearance of the rod bearings. The clearance is 0.002 - 0.003 on the rods versus 0.0002 - 0.0003 on the pins.
