Posted by pete 23 on July 15, 2014 at 20:05:01 from (74.33.72.212):
In Reply to: 986 leaking posted by 47farmallM on July 15, 2014 at 18:31:28:
A 986 has a cat 2 hitch and that left side can be pulled off and O-rings replaced without even draining the rear. Polish up any grooved or rusted parts . Parts book is confusing and shows two O-rings on right side but they are on the left side where that one is leaking. Have repaired many but they were usually on much newer tractors so wear may be a factor on this one. You need to get correct O-rings not some will fit jobbers. If it was a cat 3 you would have to pull whole shaft out to service and you also have to to do right side of this hitch.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
